Thread: Breakfast Run
Old 08-04-2001, 08:19 AM
MIKE KENNEY MIKE KENNEY is offline
Jeff,
Not that it helps now but your car has two struts that run from the front tower to the front clip on both sides these bars were not in the original cars. They were put in the Hi-Tech Replica cars and the first few Hi-Tech Motorsports cars. There are a few other small changes made to the frame as well in the earily days nothing major though. Also the nose of the car sets about 1/2" lower. Did you take the old radiator to Tim for measurements or just tell him to narrow it? The corners will need to be chop of at 45 deg angles and the pins placement the bottom should be double checked. Tim, just made a radiator for Don Growth (I hope I got the last name spelled right) his radiator should be the same as yours, or at least very, close.
If you have any other questions drop me a line.
Till later,
Mike
