Old 06-18-2007, 06:55 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
FFR428,
I am not sure which way the oil relief valve was installed. I did not install it. My block does have this provison. I hope that I will not have to remove the tranny to find out. Just for referrence are you saying that it should be installed :
Block , plunger, spring, alan plug.
Also, can anyone tell if my plumbing is correct?
Any other suggestions before I remove the oil pan?
What oil pump do you guy recommend? I figure if I am going to pull the pan for the oil pump, I might as well replace it.
Do you guys shim the pump or is it a straight install?
