Old 06-18-2007, 08:55 AM
JGC JGC is offline
Cobra Make, Engine: Superformance 695HP aluminum FE
10-15 at idle is not unreasonable. What pressure do you have at higher rpm's? You need at least 10 psi per 1000 rpms. Much higher than will cause excessive wear on the distributor drive gear and add heat.
JGC
