Old 06-18-2007, 01:10 PM
FFR428's Avatar
FFR428 FFR428 is online now
Cobra Make, Engine: HM-2027 / 427 SO
The spring goes in first, then the valve, then the allen plug last. I don't think your block has the "mystery hole" either. But if you did it would be affected by the adapter plate or later adapter oil passages bleeding into it. That dang hole was on a old 406 block I had also. I like Chanmadd's idea of trying just the stock filter and adapter...and also going to a little heavier oil. I'd document each step one at a time instead of doing a combination of things at once. I would also try the simple things before digging into it.
G.
