Old 06-18-2007, 09:53 PM
2KWIK4U's Avatar
2KWIK4U 2KWIK4U is offline
Cobra Make, Engine: Lonestar LS427, Keith Craft 496 Genesis, 649 hp, 668 ft-lb, TKO-600, Dynatek Stack EFI
I agree with Olddog. The gauge pressure port on my adapter plate is on the return side of the plate, after the oil has passed through the filters and cooler. I would first verify the gauge is reading properly, then I would remove one hose from the filter and loop it back to the adapter plate to bypass the filters and see if that makes a difference. The oil won't be filtered, but would probably be safe as a test for a few minutes. Are the pressures your quoting with the oil cold or hot?
Brad W.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
