Old 06-19-2007, 09:11 AM
cobrajam's Avatar
cobrajam cobrajam is offline
Cobra Make, Engine: Contemporary frame, Midstates kevlar body, Aluminum Shelby 427, G-force T-5
Default Need 391 Crank bolt, washer, pilot bearing
Anyone have an extra 391 crank bolt & washer, and 1-2 pilot bearings, or know of someone who does? I am using 391FT steel crank that is machined for FE, but still uses the FT hardware. The local Ford dealers won't even take time to look them up. The last time I used an FT crank, I had the center of the 391 pilot bearing machined out, and a roller FE bearing pressed in, since the inside diameter of the FT was too big. Thanks
