Thanks Brian for the response I needed
However, I have only one positive wire running to the light (Hella unit).
I presume this wire runs from the light to a switch and then onto the gearbox with the switch grounding when reverse is selected.
Is that logical?
If so, just got to trace the wire from the gearbox to the switch (difficult part) and check that the switch is grounding.
