Old 06-19-2007, 06:15 PM
jimmymac jimmymac is offline
I had oil pump bolts work loose. With about the same pressures as you have. You could check by pulling the distributor. If you can move the oil pump at all problem solved. Jim Dove can supply the adpt you need. I run it. Still you could try stock adpt. an filter. Just for testing. Be Patience
