Old 06-21-2007, 06:21 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Weber: Fuel pressure fade
Hello All,
I have noticed that when my motor starts to warm up with the IDA 48 the fuel pressure starts to drop off.
My current fuel setup:
IDA 48
Holley Blue Fuel Pump
-10 Feed
-8 return
Bypass Regulator
Fuel Pressure 3.0
After pinching the return side of the regulator I noticed the pressure increased and the car ran different at idle.
I have also seen others post the same information about the fuel pressure fading. Many comments have been made that this is normal. I would like to find out if you guys that are experiencing the same fade have a return line.
Also would like to know if you are using a dead head regulator(a regulator that does not need a return line) or a bypass (regulator with a return port)
Thanks
