Old 06-21-2007, 12:37 PM
QUICKTIME QUICKTIME is offline
Originally Posted by RodgerH
Ross,
Is it necessary to "dial in" the Quicktime bellhousing as is typically required with the Lakewood? My application will be on a Shelby aluminum FE block.
Rodger
The Quicktime Bellhousings are within .0015 concentricity and parallel. It will depend on the accuracy of the block machining not the bellhousing. Most of the time it would not be necessary, however it is never a bad idea because of the issues with the drivetrain if things are not aligned.
