Old 06-21-2007, 07:30 PM
JUS BIT JUS BIT is offline
Cobra Make, Engine: BDR #491, Red with Black Stripes, 438 Windsor by Keith Craft Racing dynoed at 640hp, Street and Race Prepped.
Snakester, I think you are right on the money at $40k. What some of the others seems to forget are all the minor things that add up.
Yes, motor $7500, Tranny, clutch, flywheel around $2800. Right there you are already over $40k (28,900+1700+7500+2800). Then you gotta add pulleys, starter, air cleaner, fuel pump, MSD, Coil, belts, hoses, miscellaneous nuts and bolts, and many other minor parts to get her done, at least another $1000 minimum. Then you got to get it all installed, dialed in, fluids added, and an alignment.
I have seen very few people get a BDR done for under $39K unless they used their own powerplant. Just my 2 cents...
Best of luck and I hope you get every penny you deserve...
James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
