Any Competent/Respectable/Reasonable Shops in Tidewater/Richmond VA
Looking for someone who would/could set up a Jag center section. Replacing the 3.31 Powerlock 19 spl stub axles with an Auburn Pro diff, 3.73 ring gear & pinion, 30 spl chromemoly stub axles. Unit is apart and all parts are cleaned or new. Have everything for it except the stub axle bearings. Will require minor machining on the axle retainers to clear the Wilwood vented rotor setup. It is basically a Dana 44. Local Jag dealer requires a VIN number to even look at it, and would not offer any additional assistance.
