Old 06-25-2007, 07:55 AM
Sam Bozzette Sam Bozzette is offline
Cobra Make, Engine: A&C , 466 Ford, 5speed Tremec
Thanks, Jerry and Roscoe.
T think I may have found part of the issue, the Vette master cyl. is reverse in connection from most I have used. The reservoir closest to the firewall is for the rear brakes and the one furthest from the firewall is for the front. After much tinkering and searching for info, I pulled the mc and bench bled it, I noticed the what I thought was the rear brake section moving much more fluid, so I reinstalled it and switched the lines and it works much better. I am still going to make some adjustments in the pedal to pivot advantage, but at least I can stop now. Thanks Again, Sam
