Old 06-25-2007, 08:01 AM
Roscoe's Avatar
Roscoe Roscoe is offline
Sam,
You may eventually want to setup for pressure bleeding. It eliminates alot of the problems inherent in other forms of bleeding brakes/clutch.
Simply put, get a reservoir cover and install a schrader valve. Pump in 5-10 lbs of air (depending on the material of the reservoir) and open the bleeder.
Also, if you have two mc's (and I don't know if this applies to you) Tilton Racing recommends bleeding left and right, not back and front.
Roscoe
Roscoe
