Old 06-25-2007, 11:58 AM
richsd's Avatar
richsd richsd is offline
Cobra Make, Engine: 427 Cobra re-creation based on Kirkham aluminum body and chassis, Original 1965 Ford 427 Side Oiler and Ford Toploader transmission
Yes a very interesting situation. It is very interesting to consider what is original in cases where original AC items were changed almost immediately. There will continue to be confusion on original certainty not only due to these type of situations but also of course since this was not an assembly line type car. In many cases, they put whatever they had on the car and did not care that it was not exactly the same as the previous cars built. I am probably with you that as I go through the filler cap change I will try to find the proper hex heads.
