Old 06-27-2007, 05:12 PM
xlr8or's Avatar
xlr8or xlr8or is offline
Originally Posted by bdeutsch
If you purchase a used cobra that is legally titled and registered in another State, does anybody know what is involved in the process of legally registering the car for use in CA?
Thanks
You basically just register via SB1578 to get it listed as (special construction). You will need to pass a smog test based on the year of the block or wait until January and get an SB100 number to set the smog rules to the year the body replicates. 1965 only requires a PCV setup. Get it tested one time with no requirement to pass other than equipment check (pcv). It doesn't have to pass the tailpipe test under SB100 it just has to be tested.
