Old 06-27-2007, 09:05 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
I was looking through Sports Car Graphic, 11/65, and it lists the comp engine as having aluminum Hi-Riser heads / intake, and a 780 cfm carb, not an 850 like was stated before. The comp car in the article appears to have a carb with mechanical secondaries, as there is no vacuum dashpot for the secondaries.
If I remember correctly, I had thought that I heard that Holley designed the 850 carb, with bigger throttle bores, for the '67 L88 vette. Like you said, maybe the 850 carb was out in 1964/65.
Anyways, here's the graph from weber I was eluding to earlier..
427 has about 875 cc per cylinder.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
