Old 07-03-2007, 05:41 AM
Dwight's Avatar
Dwight Dwight is offline
Smile starter
Is your battery in the trunk? What size cable do you have? Check the voltage at the starter solonoid when it will not start. Check and clean your grounds. Do you have a ground cable from the frame to the block? A loose clamp on the battery will give you the problems you have described.
Dwight
