Old 07-03-2007, 01:19 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Torque the pressure plate bolts to 22 ft/pounds
This is the McLeod starter that we use. It is part number 810160.
Then you will need to do something that VERY FEW people ever check. You NEED to check the gear engagement on the starter. The starter needs to have full engagement on the flywheel. If you don't get full engagement, you will chew up the edge of the flywheel ring gear and VERY SOON you will get the pleasure of taking out the interior, seats, drive line, drive shaft, clutch, pressure plate, throw out bearing assembly, transmission and FINALLY, the flywheel so you can replace the ring gear. The only thing more painful would be a trip to one of Saddam's little rooms where he "talked" to people to get info out of them, (or maybe getting hit by that drive shaft).
Here Master Sandwich is checking the engagement on the starter. Turned out it STUNK so we had to take the billet face off of the starter and take 0.080 off of the face to get it to engage properly.
You need to pull out the starter gear and make sure it has full engagement! Otherwise, you will chew the teeth off of the ring gear and destroy the starter gear. Here you can see Sandwich has trimmed the face of the starter to move it 0.080 inches in with good engagement.
