Old 07-03-2007, 03:33 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Now we bolt on the bell housing. BUT FIRST!!! We need to drill a hole in the bell housing to accept our new, cool, throw out bearing. NO MORE LEAKY hydraulic throw out bearings!
You will need to drill out the TOP hole where the clutch fork pivot normally mounted on the bell housing. We are going to use a rod end bearing there instead. I did my best interpretation of an Anasazi to draw an arrow on the bell housing to show you which hole to drill.
Then we put in the throw out bearing assembly. (Don't bolt on the transmission before the throw out bearing is in place or you will have to unbolt the tranny again!)
