Old 07-03-2007, 04:10 PM
rwall49's Avatar
rwall49 rwall49 is offline
Cobra Make, Engine: HM Ford 351w
Default Post #51
David,
Thank you for the reply. Also, I would like to know what sandwich used to drill out the dowel pin holes with, since I believe they need to be accurate holes. Did he use a drill press or just a hand drill. Are these holes real critical. And do you weld the dowel pin bushings in after your final centering of the bell housing. I assume that once this has been done the first time that removing the bell housing to replace clutch etc. will be centered the next time it is put back on the engine.
