Old 07-03-2007, 04:50 PM
Rick Parker's Avatar
I too am going to have it done. Pierce is a couple of hours away, I am going to attempt to take them there and have it done without having to leave the carbs there. From what I understand they screw a fixture into the access hole behind the brass plugs and line it up with the existing 2 holes and run a
.9 mm drill through the drill guide fixture. It is imperative to have the holes in the EXACT same location in relation to the throttle plate for each carburetor. This is not a procedure you would want to attempt without the drill guide. It is not a lengthy procedure, just exacting.
Rick
