Old 07-03-2007, 07:15 PM
sirreal sirreal is offline
Cobra Make, Engine: Venom 427, Ford Racing 392ci/430 hp
Default starter problems
The starter turned over when I tried it tonight, however per most suggestions I started at the battery and worked forward to the solenoid. The battery pole connections were slightly lose, the battery ground was very tight, The cable from the battery to the solenoid was lose, the cable from the solenoid to the starter was tight. I went for a ride in traffic and came home and it started right up. I then waited 1 hour and it started right up again.
I will install a second ground from the block to the frame this weekend as suggested.
I hope this will cure the problem.
I want to thank everyone for their help
Rich
