Old 07-06-2007, 12:18 PM
GreenSnakeDoc GreenSnakeDoc is offline
Thanks for a good answer Michael. It seems like the FFR Cobras are the lightest, maybe 2150 lbs. with a 302 which should mean 2250 with a 351W. That means that the LA Exotics and B&B's are approximately 400 lbs. heavier.
I bet your Cobra has quite a bit frame reinforcing, expecially for the door hinge area and their fiberglass bodies would be thicker and heavier also. Would the 40 year-old design 4 speed top loader be heavier than a modern 5 speed that can handle the same power? I bet the 9 inch weighs more than the 8.8. It seems that every thing done to improove and strengthen most replicas over the originals adds weight. This is probably good for protection if you get hit by another vehicle, but slightly bad for performance. Of course performance compared to original street Cobras can be made up for these days with a 408W that can make more power than the original 427's, improved tires that will corner better and larger brakes that will stop better. Does anyone have any modern replica 0 to 100 to 0 times? Whatdayathink?
