Old 07-07-2007, 08:41 PM
lineslinger's Avatar
lineslinger lineslinger is offline
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Neutral
Originally Posted by Velox
That's just the clutch reservoir, it is not the pressure line to the slave, that hose is just the fill tubing going TO the clutch master, not the pressure line going out from the master. That connection on the reservoir sometimes leaks, there is an o-ring fitting where the top square plastic reservoir fits into the lower round plastic portion that leads to the hose. I just replaced mine, no more leak
You got it Velox, thats why I raised the question.
