Old 08-07-2001, 08:08 PM
a427sc a427sc is offline
What are the noise restriction level you need to meet? And how is it to be measured? WFO on the front straight with aluminum grandstands and walls all around (NHIS-99), at the end of pit lane on the front straight or where ever the sound person wants to go, with wide open spaces all around (LRP-86), 3000rpm @ 50 ft? or...
The cones are good for about 1-1 1/2db, Trapps about 2 before it all goes to h**l. CCI's I have no experience with. You need a good muffler to get most of the noise out, these other pieces are for final tuning out the last couple of db.
I worked out a set-up for NHIS that passes by trial and error. 24" Lobacs, 3 1/2" vortex cones, and Trapps (actually the set-up shown in Kit Car Louden article). Got a sound meter at Radio shack (same as they use) and set up a test facility to compare differences. 99 at NHIS worked out to 92 @6500/3rd gear at 50 ft out in the farm country. I now have a base line to compare different combos for sound/performance degredation. Burns stainless makes clamps that make changing mufflers easy. good luck.
Don
