Old 07-09-2007, 04:34 PM
Ant Ant is offline
Default Pin drive pins
Thanks Rick, Larry,
I am using Trigo pin drives on the rear, with HT 1/2" bolts, as my new 1999 - 2004 Cobra mustang hubs are only 4.5" pcd and these Compomotive wheels are 4.75"........bugger I thought I had the right PCD, and as these hubs are the same OD as the normal T/bird I only have about 2.8mm material which should be okay as the stress is rotational and I am making my own hubs so I can spigot them!
Rick,
On the front we are now going to make (6) 3/4 x 7/16" the 7/16" shank which will go through about 6mm on the inside to mount a rotor hat, I have looked at some factory BMW race cars etc and they employ a simple system like that but have the pins quite pointed for quick change of wheels!
A J. Newton
The 1960's rocked!
