Thread: Oil Cooler
Old 07-10-2007, 07:54 PM
JUS BIT JUS BIT is offline
Cobra Make, Engine: BDR #491, Red with Black Stripes, 438 Windsor by Keith Craft Racing dynoed at 640hp, Street and Race Prepped.
Patrick, you don't need the cooler on that motor you have. The radiator is going to to your water system plenty cool enough that the oil will never get that hot.
By the way, the reason your oil temp is running around 50c is because you are measuring that temperature out of the pan. The blowby air is keeping it cooler because the oil gets stuck near the sender and gets cooled. Most likely the oil temp sensor is on a splitter with the oil pressure sensor. You would have to install it in the pan to get a better reading.
Best of luck, James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
