Thread: Oil Cooler
Old 07-10-2007, 09:27 PM
FST FOX's Avatar
FST FOX FST FOX is offline
Cobra Make, Engine: #42 BDR w/ a 408 KCM stroker
Originally Posted by JUS BIT
Patrick, you don't need the cooler on that motor you have. The radiator is going to to your water system plenty cool enough that the oil will never get that hot.
By the way, the reason your oil temp is running around 50c is because you are measuring that temperature out of the pan. The blowby air is keeping it cooler because the oil gets stuck near the sender and gets cooled. Most likely the oil temp sensor is on a splitter with the oil pressure sensor. You would have to install it in the pan to get a better reading.
Best of luck, James
great thanks, btw pm sent about the instructions also answer my other thread about the E-Brake, please
2006 King Ranch F150 Supercrew
Personal vehicles-2007 Escape
2004 BDR #42 with a 408 Keith Craft Stroker, Crimson with Silver stripes
