Old 07-10-2007, 10:24 PM
yamahaSHO yamahaSHO is offline
Cobra Make, Engine: '02 Civic EX Coupe & '95 supercharged SHO
Send a message via AIM to yamahaSHO
Originally Posted by lineslinger
Impressive engine, I can see how space in that compartment would be at a premium. Here is a shot of a Canton sandwich adapter with a thermostat, the outlet fittings are 12AN.
I am not sure what the constrictions are that you speak of in terms of needing a spacer, do you mean to separate the filter setup farther away from the block laterally or extend the setup farther down or closer to the road?
Do you have a link where I can find those fittings? From that picture, it looks as if those fittings do not extend as far as the swivel fittings I've seen.
