Old 07-11-2007, 03:58 AM
blykins blykins is offline
The biggest deal with the FE is making sure the heads and the intake are perfectly flush with each other....because they make up the valve cover flange. Of course, a lot of this is done at assembly time. If you're trying to make up for a little step up in that area, I put some RTV on the joint and build it up a little if necessary. I've had good luck with the cork gaskets.....and the Felpro rubber gaskets work well too.
