Old 07-11-2007, 12:53 PM
Nantucket427's Avatar
Nantucket427 Nantucket427 is offline
Cobra Make, Engine: Superformance#1325, Miller Machine FE
Default Never had a problem with Cork
The motor has to be put together right or they leak. If you have to much oil in the heads you can not keep it in.. Miller Machine in Haverhill MA did mine. Phill is an old drag racer and has forgotten more about FE motors than I will ever know.
I use permatex (red) to stick the gaskets to the Valve Covers, don't over tighten the the valve covers (the alumium covers are truer than the steel)
I run Diesel Motor Oil which I think is a component of the no leak FE.
Everything has a downside, so dwell on the positives. Find humor in the tough times.
