Blas
What did they do to your fuel line? The SP's that I've seen , I think that the fuel line could be routed inside the left frame tubing very easily and be completely protected from the drive shaft/ flywheel/clutch areas that are a concern---the battery cable could be routed up the other side the same way--this would completely eliminate any possibility to damage either from a mishap racing or simply raising the car on a lift
Jerry
