Thread: New Spf 2585
  #23 (permalink)
Old 07-15-2007, 06:16 AM
greg schroeder's Avatar
greg schroeder greg schroeder is offline
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
Originally Posted by BLUE427
Greg,
You Were Right, I Have Over 1200 Miles On The Tko 600 Now And The 2-3 Shift Is Getting Much Better, A Bit Of Break In Helped A Ton, Thanks For The Info. Do You Still Think That Slick Shift Stuff Cobra Valley Sells Would Be A Good Idea, Or The Pro 5.0 Or Leave Well Enogh Alone?????/
The trans from Tremed comes out of the box with a list of the few products they sugest. It seems you can get pretty good shifts with the recomened lubricants. I'm not sure what other products would do for the syncros. Maybe call up Tremec and ask.
I'm not sure what Superformance has done with the headers. The set I had that came with car 2040 covered .3 inches of each exhaust port width. I'm not sure were the Olthoffs got my replacement headers. They are a 2 inch primary though. The inlet doesn't cover the exaust ports on the AFR 205 heads that Roush uses. The side pipes I went with are from buckshotracefab.com. They work pretty good.
