Old 07-16-2007, 09:55 AM
kris-kincaid's Avatar
kris-kincaid kris-kincaid is offline
Cobra Make, Engine: 427 SC
Send a message via AIM to kris-kincaid Send a message via Skype™ to kris-kincaid
HST is installing smallblocks in export (non US) Cobra's. They should have everything you need
I also installed a small block in a CSX car. The car had a 347 with a TKO. I used Kirkham motor mounts and a custom trans mount. I used the 427 sidepipes, making my own headers. The headers were a bit of a challenge because I had to step them from the tiny small block exhaust ports to the 2" 427 sidepipes. The engine was the same that McCluskey uses in the Coupe's and was very healthy. The car sounded like an FE and had plenty of power.
The only reason I did it was because the car was going overseas and it would be easier to import with the smaller engine. I think the owner plans on taking out the small block and putting in an FE once it clears customs!
