Thread: Overheating
Old 07-18-2007, 11:48 AM
tcrist tcrist is offline
JCZAR,
Was the car overheating when you changed the water pump? Your first post said that you changed it because it was leaking. If it was only leaking and did not overheat when you changed the water pump, then I would think that the water pump does not have enough flow. A smaller impeller could cause that.
Terry
