Thread: Kirkham on eBay
Old 07-19-2007, 08:14 AM
turnpike boy turnpike boy is offline
Cobra Make, Engine: Unique 427SC/331/5 forward
And - by the way - a PCV valve essentially closes during hi vacuum periods, preventing hi vacuum in the crankcase. This is why you connect to the manifold directly....if you put a breather in the system, you are putting a comparatively large quantity of unmetered air directly into the intake system, with resultant screwy results - unsteady idle, weird metering, rough/rich/lean running, etc.
What you need is the right PCV valve. You might have to do some research on this but the info is out there.
