Old 07-21-2007, 02:47 AM
westcott cobra's Avatar
westcott cobra westcott cobra is offline
Cobra Make, Engine: Actual car: AC Autokraft MK IV with Keith Craft 331. Gone: Home built Crendon, original style twin tube frame, powder coated, stainless sidepipes. FE 433
Back with some update.
Nothing happend the last few weeks because of lack of parts and time.
But now we are 2 days from final assembly.
What we did:
Monday, June, 16th.
- Replaced the rod bearings with new melling parts. Checked them all out of the box and found 1 pair foulty, spotty surface. Order a new set from the US...
-Installed the oil restrictors again, the new crane solid roller cam, ARP main studs, crank, pistons and timing gear with one rod bearing missing...
-tried to assemble the heads with the new crane double springs and decided to mill all spring seats from original 1.8 to 1.9. Together with new +retainers and +0.05 locks we are going to get 2.0 installed height. Order new retainers and +0.05 locks from the US.....
- Yesterday we milled all the seats. Together with the new locks, hardened shims on bottom and retainers we are about 1.95 all arround with 1/10th of a millimeter difference.
- I checked the oil pump rod(ARP) to dizzy endplay. With the oilpump(without gasket to be on thesafe side, the dimension will be even bigger with it....) and dizzy in place i have 1.5 Millimeters end play measured at the rod, enough.
- Checked the dizzy gear to block clearence, 0.8mm, enough ! Timing cover was off for that work. I replaced the lousy dizzy clamp with a new MSD milled clamp to get the clamp pressure centered on the dizzy shaft. Dizzi will be installed with a 0.3 hardened shim between gear and block as i did last year for safety.
- Checked the fitting(center of the crank) of the brand new Summit 351C timing cover. Correct !
- Painted the block, water pump and timing cover in Ford dark Blue SP-125 !!
The rest of the work will follow on Sunday or next week.
I put some new pictures in my gallery, check them out.
I'll keep you updated,
Uwe
Everything should be as simple as possible - but not simpler !!
