Thread: Timing Curves
Old 07-22-2007, 08:39 AM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Default Timing curve
Hi,
It looks like a good plan. It probably works good like this because the MSD actually can runabout 2 to 4* more advance than you would think.
The top end retard is good also,not as hard on the rods.
I would pull the plugs and check for detonation ocasionally. Instead of tan the plugs will have a yellowish spot or actuall start burning the electrode off. If the plugs read OK I think you are set.
Perry.
