Old 07-22-2007, 10:36 AM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Default Timing
Hi,
Get the timing light out and retard your ignition to 6*. Pull out black plastic spout 1st,then set timing. Also make sure engine is HOT, at least 190*, if you have a lower thermostat then put cardboard infront of rad.Also clean the blade on the throttle body with brake clean, hold open and wipe the edges, that is where the .003 air gap is and will gum up easily.
Perry.
