JAC,
As you are saying that your shaft is .012 under 9/16 in size, maybe it is a metric sized (14MM) shaft on your rack? Also Don offered to replace your rack with the Flaming River one. You might want to take him up on that. On another note, did you order the rack seperate from your kit or was the rack included in the kit? If CR sent you a rack and it was not a Flaming River then they should at least be able to tell you tha manufacture and P/N of the part so you can get the correct size connections.
Terry
