Old 07-22-2007, 12:14 PM
68gt500's Avatar
68gt500 68gt500 is offline
Cobra Make, Engine: Sorry "just" a 68 Shelby GT500
Send a message via Yahoo to 68gt500
Default Installed the Webers - its running!
I got them installed an running .
First test ride showed it way lean on transition (about 1600 rpm)
My supplier could not get the idle holders in the specified 100 size, so I tried the stock 120s - not good.
So I soldered the 120 shut and drilled new 1mm holes.
Runs much better now but still has a lean hole at about 3000. I still have to check ignition advance, since my distr. was optimized for vacuum advance.
Probably need more initial.
My setup now is:
Idle 65
Idle Holder 100
Air corrector 120
Emulsion Tube F16
Main Jet 150
Venturies 40 mm
Basically a copy of Stefans "mallorca special" but using F16 because I could not get the F14
What would you suggest as next step to get rid of the 3000rpm lean spot?
Yes, I do have a wideband O2 to check - great tool btw.
Mike
68 GT 500
(Germany)
