Old 07-23-2007, 09:38 AM
patrickt patrickt is offline
Originally Posted by CobERA
My coil is brand new (since the first stall) and my old coil was mounted the same way. Do you think sideways mounting could be the problem..
No, there are a zillion MSD coils mounted that way. The fact that it is dying on you regularly will actually help you. Put a can of starter spray in your trunk and, like Trularin said, when it dies, quickly try and start it with a couple of spritzes down the carb. If it doesn't start, pull the wire to plug #8 and hold it while you crank the ignition key (you can easily reach both). I'm betting you won't get any shock and, if I'm wrong, it won't hurt that much anyway. Doing those two things will get you closer to the final answer.
