Old 07-23-2007, 01:38 PM
CobERA's Avatar
CobERA CobERA is offline
Cobra Make, Engine: ERA #644 428 FE
Thanks for the ideas. In response:
  • Yes, my fuel tank is vented.
  • re: the MSD box, I was under the impression that they are either bad or good. I did not know they could have intermittent problems. Is there a way to test them?
  • My fuel lines look like the picture. Looks like a easy, cheap swap. I guess it can't hurt to change it.
  • I'll also check to make sure there are no wires that could be touching the fuel lines and sending current through the braided lines. I have already checked my grounds and haven't spotted any problems.
I've now got a short check list of diagnostics to try if (when) it happens again:
  • Pull air cleaner off and check to see if fuel comes out of squirters when throttle is applied.
  • Squirt starter fluid down carb and see if it starts.
  • Pull coil wire from distributor and look for a spark.
  • Pull #8 wire and look (hopefully not feel) for a spark.
  • Check coil with multimeter.
D-Doug - Good point about the beer/tequilla! Once we figure this out, I'll owe one of you guys.
Rick
ERA 644
I'm getting old too fast and smart too slow!
