Thread: it stalls . . .
  #22 (permalink)
Old 07-24-2007, 11:23 PM
RedCSX1's Avatar
RedCSX1 RedCSX1 is offline
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Default Yep!
Originally Posted by Chaplin
Rob-
The inability to cruise at 1500 rpm is more likely a function of your cam than your carb. I imagine your motor probably has a pretty big cam in it- in all likelihood it probably won't run smoothly until 2000 rpm or so regardless of what carb you have on the motor.
But that being said, a smaller carb will have better throttle response than a bigger carb. IMO, if you do a lot of street driving and are not worried about hp in the 6k rpm range, putting a 750 on is not a bad idea and will likely increase low rpm throttle response, but you will lost some top end hp. It is all a give and take.
My motor now will idle no problem at 1000 rpm's and will not stall however it does not run smooth at under 2500 rpms. The reason is the cam. 630 lift.
Morgan LeBlanc
Fresno CA
