  #25 (permalink)
Old 07-25-2007, 01:25 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
[quote=Excaliber]I also was wondering about the harmonic balancer on the SOHC engine. /QUOTE]
Actually the harmonic balancer and balance are 2 different things. The harmonic balancer became fairly standard on all FE engines by ,I believe..1966, they were the same regardless of engines. The 428(all except SCJ) used a weighted Flywheel and the SCJ version also used a weighted "hatchet" behind the balancer. Although on small blocks,all external balanced, the damper also acts as a weighted piece... on FE's they have no weight and are just to absorb vibrations. I believe the change was made for 2 reasons, one is rpm's increased for HP engines at that point and more options became available and instead of a bunch of dampers with different pulleys they made the pulley and damper as 2 pieces. Unlike early FE's that had a single pulley made into the damper.
WDZ
