Old 07-26-2007, 10:04 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Hello All,
Ok update I spoke to the Engine Builder and he told me that the mains are : .0022 and the rods are .0025
I think that this falls with in specs.
I pulled the pump and everything looks fine. I called Melling and they told me to determine if it is a Hp pump the gears will be 7/8.
A HV pump will have 1 3/32 tall gears. I will check measurement tonight.
I pulled the pump apart and everything looks fine. I am thinking of replacing the spring in the pump or would you guys recommend replacing the entire pump?
I guess next stop will be the bypass at the back of the block. I really dont want to pull the tranny
