Old 07-26-2007, 05:36 PM
Philm's Avatar
Philm Philm is offline
Default Depends on how you look at it.
The move to the OHC engines only created a perfect opportunity for aftermarket blocks and components.
The small block windsor is now better than ever, blocks from Dart, world are affordable and almost indistructable. You can even get alloy blocks if money is not a problem.
I think the real tragedy is that although the basic size and configuration is the same most high performance "Ford" small blocks would not have any geniune ford parts in them.
Phil
