Old 07-26-2007, 10:05 PM
Paul F Paul F is offline
Senior ClubCobra Member
Default Compomotive Wheel Spinner - Doesn't fit?
I've got a set of Compomotive HB pindrives. The chamfer of the spinner just barely engages with the chamfer of the wheel (see attachments). This doesn't seem correct. I would have thought that the face of each chamfer should be in full contact with each other just like a lug nut engages with a wheel. You can see the score mark on the spinner where it contacts the wheel. The wheel picture isn't very good, but you may be able to see that the spinner is sticking out quite a bit. Its as thought the spinner is too big.
Is this normal?
