Old 07-27-2007, 06:03 AM
tcrist tcrist is offline
I would not use starting fluid. It will dry out the cylinders. Rinse out a soda or beer can and put some gas in it. Pull off the breather, open up the butterflies on your carb and drip in a littlt gas. You do not need to much. Make sure not to spill it on the carb or manifold. Put the can of gas away from the car and try and start it. You might have to do this a couple of times to keep it running.
Terry
